No Internet
maxineannette
No Internet
i was told my broadband was connected yesterday after some delays but I have tried to connect to the internet today but it isn't working.
The internet light on the router is red and when I try to connect using the broadband set-up page is says my username and password may be incorrect. I have re-entered them and that didn't work so I reset the router.
When the router first starts up there is a completely different username in the box but I changed it to the correct one and it still isn't working.
I don't have an ethernet port on my computer so I have to connect wirelessly. I have checked the micro-filters are ok and the telephone line is working.
Can someone please advise?
Thank you.
Fixes: 231
Re: No Internet
The account wasn't in the right state.
If you reboot your router it should work.
 Matthew Wheeler
maxineannette
Re: No Internet
Thank you very much for the quick help. all up and running perfectly now Smiley
Fixes: 231
Re: No Internet
Glad to hear it's working Smiley
 Matthew Wheeler
