No Internet
cappismum
No Internet
Hi
We had storms on Sunday and my internet has been off line since then.  I keep getting the Thomson Gateway page saying Enusre you have joined up etc, words to that effect.
I have reset my router but to no avail.  I am at work at present so not able to provide any data from my home computer.
Are there any issues in South Wales please.
Fixes: 162
Re: No Internet
When you receive that Technicolour page are you able to log in to the router using admin as the username and the serial number (starting CP) as the password?
Your router is actually connected through to us at the moment, so it's just a case of ensuring you can connect to the router locally now.
 Chris Parr
 Plusnet Staff
cappismum
Re: No Internet
No I cannot log in from that page.  When I have reset the router before the log in page appears but this hasnt happened this time
Fixes: 162
Re: No Internet
The simplest way to resolve this is a factory reset of the router, however it's not something I like to suggest really. Before going down that route can you try following these steps:
- Open your browser and go to 192.168.1.254
- Enter the router username and password (admin and the serial number)
- Go to Technicolor Gateway on the left menu, and click Configuration just below this, then click Configure in the top right hand corner.
- Change the drop-down for Web Browser Interception from Auto to Disabled, click Apply
 Chris Parr
 Plusnet Staff
