No Internet This Morning
gillig
Hi there, not sure if this is the correct place to report this but I had no internet access this morning.
The internet light was not lit on the router, tried a reset etc but no joy.  I'm in the PA12 area if that helps.
At work now, so not sure if it was a small problem that's now been fixed, but thought it best to let you know.
Cheers.
Fixes: 65
Re: No Internet This Morning
I've just run a few checks and can see that there is a known issue in your area at the moment which our suppliers are working on.
They've given an anticipated clear time of 2pm so drop us a reply again if you still have any problems beyond that.
Adam.
 Adam Walker
gillig
Great, thanks Adam. Will hopefully be fixed by the time I get home!  Smiley
Fixes: 65
No problem, I just stumbled across this post again and thought I'd check your connection logs, glad to see that you've reconnected.
 Adam Walker
gillig
Haha, me too!  Grin
