No Email
the_groundsman
No Email
Very odd. When I started Outlook this morning it showed about 20 messages to download and froze about half way through. Now I get errors on all my email accounts (Some plusnet some others) all saying operation timed out. Any ideas?
the_groundsman
Re: No Email
I rebooted all fine now. Why can't you remove your own posts to save your blushes  Embarrassed
pierre_pierre
Re: No Email
yes
Re: No Email
Quote from: the
There is a 'remove' button on your own posts thatl ets you delete your posts.
Fixes: 62
Re: No Email
But not the first one in a thread
pierre_pierre
Re: No Email
You could edit the first comment and delete your second
Or ask a moderator nicely and he will delete it
