No DSL light fault resolution
- No DSL light fault resolution
- « Previous
- 1
- 2
- Next »
Re: No DSL light fault resolution
14-08-2013 5:32 PM
Removing the fibre faceplate should be fine, it's easy enough to put back on if need be as well - though to be honest, if it doesn't work with the router in the fibre socket then I'd be surprised if it was there in the test socket.
The provisioning agent who's looking after this for you should be updating the ticket later on with details of the expedite, if not this evening then definitely tomorrow.
14-08-2013 8:24 PM
Still doesn't explain why if I've been reverted to my old broadband why it isn't working. Hope nothing else is amiss!
15-08-2013 8:18 AM
15-08-2013 9:56 AM
15-08-2013 10:06 AM
15-08-2013 10:22 AM
Either way though this isn't helping the current situation - though not a lot will, apart from getting the order expedited and completed. I concur though, it's definitely weird.
15-08-2013 10:51 AM
I absolutely agree, and I assume provisioning are actively chasing that up as we speak. I'm just concerned that gary396 isn't given false hope that he still has an ADSL service and that if BT think that also, then they might not give any priority to expedite.
Quote though not a lot will, apart from getting the order expedited and completed
That report is VERY strange!. It would appear that BT never acknowledged the change to Fibre, which sort of makes sense in that they still thought an install was required.
That last synch speed is odd though, 20Mb is way too high considering it was originally at 6.5Mb. It looks more like a low Fibre synch than an ADSL2 synch.
Anyway I'll let you guys get on with sorting out the mess
15-08-2013 8:07 PM
Anyway, still no internet this morning when I checked about 8am (not expected to be on as above) but by 9am it was mysteriously back on - a day before the BT engineer is due to attend (now confirmed for Friday afternoon). So it would appear that someone at BT decided they could 'flick the appropriate switch' after all. Being using it on/off all day and no obviously problems - download speed just checked (wireless) at about 36Mbps - nowhere near the max but that is wireless via the Technicolor router (don't know if that makes a difference) and I can settle for that. Must test a wired connection one day. Got a call from PN mentioning that they had also noticed the re-connection but agreed to still wait for BT engineer tomorrow to attend, check and hopefully clear the job down without disconnecting me this time.
16-08-2013 9:53 AM
- « Previous
- 1
- 2
- Next »
