No Broadband since Sunday
russelc
Due to BT reported problem at me local exchange we have had no broadband or phone line actkve since Sunday evening. Whilst I understand that Plusnet are dependent on BT engineers to fix issues of this kind I have no confidence that BT are actually working the issue as I get no updates on progress.
Strangely none of my neighbours have been affected by this issue so I struggle to see why this is taking so long.
Any advice to help me speed up and conclude thjs issue would be gratefully received.
8 REPLIES 8
Legend
Fixes: 219
Re: No Broadband since Sunday
@russelc If the problem is at the local exchange, it could well be a line card or frame issue. Your neighbours may not be on the same set of equipment.
Unfortunately, there is no way to speed it up - Openreach have total control over this kind of issue, and work as they see fit. Also, they could be waiting for parts/manpower.
Mustrum
Fixes: 76
By any chance are you in the Broadstone/Corfe Mullen area? There was a lightning strike there on Sunday, a friend was impacted.
You could try entering you phone number in the BT Service checker, it may show if there is an issue.
https://www.bt.com/help/check-service-status#tabpanel-broadband
russelc
Thanks for the rapid response. Guess I will just have wait.
russelc
No we are not kn that area.
Thanks for suggestion, I will try that.
russelc
No we are not in that area.
adamwalker
Fixes: 216
Hi @russelc, sorry about the issue with your service. I've checked your account and can see you called in, we've reported a line fault to Openreach and should have an update tomorrow for you.
 Adam Walker
russelc
Another day and no updates. Been 8 days now.
adamwalker
Fixes: 216
Sorry to see that's still to be fixed, I  can see we've got an engineer appointment booked in for tomorrow with you so I'll make sure we follow things up as soon as we can. - Adam
 Adam Walker
