No Broadband 2days
- No Broadband 2days
No Broadband 2days
on
02-07-2021
8:54 AM
- last edited on
02-07-2021
9:19 AM
by
I've had no broadband for 2 days, tried the master socket thing etc. Nothing, phoneline is working. Tried tweeting plusnet got no reply. Username [Removed] Please get the service I pay for working again! Getting fed up with Plusnet to be honest, may find a different provider, so much for your award winning service!
Moderators Note: Personal information removed
Re: No Broadband 2days
02-07-2021 9:18 AM
Good morning, @MMoor1 First question, so I don't offer incorrect advice - are you on ADSL or FTTC?
Hopefully, now you have posted on the forums, one of the Help Team will pick this up - they have the ability to interrogate the system to determine the problem.
As an aside, if this problem is in the BT network, it would follow you to a new ISP - unless you switched to Virgin or you had a totally independent Fibre provider in your local area.
02-07-2021 9:43 AM
Hi @MMoor1
I've done an escalation on this request (I hope your health has improved since your last post).
You say the telephone is working, but is the line quiet?
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below. From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link. NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
Which router are you using? What lights / colours / status are showing?
Have you followed the broadband trouble shooter - see the link below.
The most pragmatic approach would be to raise a broadband fault report if the phone line is quiet.
02-07-2021 10:06 AM
02-07-2021 10:08 AM
02-07-2021 10:10 AM
02-07-2021 10:12 AM
02-07-2021 10:44 AM
This suggests an intermittent wet joint. Doing QLT repeatedly can temporarily fix such issues. Try ringing the land line and see if the router establishes sync (b light not red).
Run the phone fault diagnostics.
02-07-2021 11:18 AM
02-07-2021 11:41 AM
Hi @MMoor1, thanks for getting in touch and I'm sorry to hear you're having trouble when trying to get online recently. I can confirm when checking your connection from this side I can see the details the router look to be authenticating the connection with don't look to be matching those on your account which would explain the lights you're seeing. (This most commonly caused after a recent password cahnge on the account when the connection next drops and the router doesn't update automatically.)
I can see the router information looks to be in place our side so I'm not sure why the new details weren't pushed through to the router. To trigger this you could factory reset the router although if you've made changes to things like your wireless settings then to avoid this I'd recommend going through the manual authentication steps below.
Factory reset:
This can be done by pressing a pin, cocktail stick etc.. into the "reset hole on the back of the router for 5-15 seconds. You should see the router reboot and then within a few minutes hopefully this may have resolved the issue you're seeing.
How to log into the router and manually update the authentication details:
1) To connect to your Hub One, you will need to open a browser and go to http://192.168.1.254
If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Broadband.'
4) You will see some default options, if not, please press 'Disconnect' on the right and this will allow you to change the Username and Password.
5) For your username, this should be your account username and should be in the following format: username@plusdsl.net
Your password is your account password
6) Press 'Connect' and you should be online.
Let us know how it goes and I'm confident one of these above 2 steps should help in getting the connection back to normal for you.
02-07-2021 3:25 PM
Hi Ben,
The user reports that the line is noisy - does a CLT report a clean bill of health? Could a high error rate inhibit auto update … which would need to occur before establishing a PPP session?
02-07-2021 3:35 PM
