No ATM Detected
- No ATM Detected
No ATM Detected
06-12-2011 12:38 PM
I have moved over from BT to SKY for my phone line and since doing this middle of last week I have been getting no interner, the light flashes green for a couple of seconds and then goes off, it is one of the Thomson routers.
If I login into the router it says no ATM has been detected?
Can anyone help as I hate paying for something I am not receiving.
Thanks in Advance
Re: No ATM Detected
06-12-2011 2:34 PM
Sky may well have moved your phone line away from the BT network onto their own equipment, in that case your internet would go off. Are you aware if that was the case?
Jojo
Re: No ATM Detected
07-12-2011 9:52 AM
Re: No ATM Detected
07-12-2011 11:13 AM
Re: No ATM Detected
07-12-2011 1:37 PM
Matt, thanks and what happens if they say they can't move it back to BT as I am sure they may try that and then get me to switch my broadband to go with them?
Re: No ATM Detected
07-12-2011 3:25 PM
Your broadband will go off because it seems SKY have physically moved your line from BT equipment over to theirs, as the broadband is supplied from BT equipment it no longer has a line to be provided on. Because of this you will either have to have your broadband with them or bring your phone line back to us, you can't have both.
Jojo
Re: No ATM Detected
07-12-2011 3:29 PM
Re: No ATM Detected
07-12-2011 3:52 PM
Is this Sky's way of trying to get people with Sky taking out broadband with Sky?
So plusnet won't work with sky?
So am I right in thinking I am stuck in a contract with Plusnet and Sky and to move from either it is going to cost me?
Re: No ATM Detected
07-12-2011 3:58 PM
Re: No ATM Detected
08-12-2011 9:12 AM
The only way we could move it back would be to place an order to transfer the phone back to us (and then most likely place another order for the broadband) for which we wouldn't be able to waive the costs I'm afraid. It'd definitely be worth calling Sky to find out what's going on and if they can move the service back onto BT equipment, they should be able to do that and maintain control over the phone whilst leaving the broadband with us as far as I know.
Good luck
Re: No ATM Detected
09-12-2011 11:38 AM
I have updated it in my account settings, will that automatically sort it? Or do Plusnet have to do something?
Re: No ATM Detected
09-12-2011 11:43 AM
Re: No ATM Detected
09-12-2011 1:09 PM
I've checked the number in a couple of different BT checkers and it's definitely an LLU number. Unfortunately when a phone line is moved to LLU any BT based broadband services are removed and as Jim says you won't be able to get a BT based service (including ours) onto the line unless it's moved back.
Re: No ATM Detected
09-12-2011 3:41 PM
The easiest option would be to cancel the line with sky (would a 14 day change of mind period be in place)? and connect to plusnet for my phone line?
The other option to end my contract with Plusnet that started in Feb 11 and that would cost me a couple months internet? right?
Re: No ATM Detected
09-12-2011 3:51 PM
