Night Time Usage - Mid-night or 1am?
zedingrove
So night time usage according to your faq's it starts at 1am but your front page sells it as mid-night.
Well!  Huh
Fixes: 135
Re: Night Time Usage - Mid-night or 1am?
http://www.plus.net/support/broadband/products/res_broadband_faq.shtml#monthlyAllowance
Quote from: FAQ
Overnight usage (between Midnight and 8am) does not count towards your monthly usage allowance.
Customer and Forum Moderator.
zedingrove
Update to my post....... http://www.plus.net/support/dial-up/info/night_time_access.shtml ; 31k
That's the addy for the night time access faq
cheers
Fixes: 62
That is for the old Dial Up Anytime Accounts as it says at the top  Grin
zedingrove
Like I am supposed to know that, have been connected with plusnet all of 5 hours, and when I read Anytime account started to look for what account I am on, found one thing that said "Always on" so took it as Anytime. Then figured was on Value package from front pageHuh?
Undecided
Fixes: 21
Never mind you'll get there eventually  Grin
Fixes: 62
This would have given you a hint  Grin Grin
zedingrove
Sorry am lost! What would of given me a hint? or do are you referring to the Value package part?
Cos if that is the case then sorry should you not add an faq: for Value package, for when someone does a searchHuh?
adie:quote
Fixes: 21
Blame the search engine  Lips are sealed  I'll add to that other post later when I've had a bite or 2.
Fixes: 62
Quote from: zedingrove
The bit in the yellow box in the picture and the reference to guaranteed hours
