Nice people but not a lot of help
- Nice people but not a lot of help
Re: Nice people but not a lot of help
05-10-2015 2:48 PM
NO GOOD NOW
1. Best Effort Test: -provides background information.
This may be as a result of my upgrade this day ?
Download Speed
0.44 Mbps
0 Mbps 0.5 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.44 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
Additional Information:
Your DSL Connection Rate :1.41 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.5 Mbps
05-10-2015 6:55 PM
07-10-2015 11:45 AM
07-10-2015 3:15 PM
Quote What is the target SNRM on this line please? Is it 9dB? Will it work (with stability) at 6dB? That might give another 200kbps, not much but a little bit of help.
Target SNR is indeed at 9db, sync is now at 1899. I wouldn't want to make any further changes until the phone issue (see below) is sorted.
Quote My phone line was very noisy and failed yesterday as did internet
I can see we've raised the phone fault to Openreach as if it's intermittent and losing service/noisy then that's really not going to be helping the broadband.
07-10-2015 5:00 PM
Home
Services
Settings
Site Map
System Info
Broadband
LAN
Firewall
Logs
Diagnostics
Status Link Configuration Routing DNS Resolution
Summary Status
DSL Link: Connected
Internet: Connected
Internet Details
Broadband Link Type: Built in modem - ADSL
Connection Type: PPPoA
User Name: stathe@plusdsl.net
Current Internet Connection:
IP Address: 81.174.133.160
Subnet Mask: 255.255.255.255
Default Gateway: 195.166.130.140
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
Host Name:
Domain:
MAC Address: --:--:--:--:--:--
MTU: 1500
DSL Details
Modem Type: Built in modem - ADSL
DSL Line (Wire Pair): Line 1 (inner pair)
Current DSL Connection:
Down Up
Rate: 1899 kbs 687 kbs
Max Rate: 1821 kbs 680 kbs
Noise Margin: 9.5 dB 5.9 dB
Attenuation: 63.0 dB 43.4 dB
Output Power: 16.1 dBm 12.1 dBm
Protocol: G.DMT2+ Annex A
Channel: Interleaved
DSLAM Vendor Information Country: {46336} Vendor: {BDCM} Specific: {42915 }
ATM PVC: 0/38
Rate Cap: 1821 kbs
Attenuation @ 300kHz: 63.0 dB
Uncanceled Echo: -16.3 dB Ok
VCXO Frequency Offset: -29.2 ppm Ok
Final Receive Gain: 29.9 dB Ok
Excessive Impulse Noise: 0 Ok
Traffic Statistics
IP Traffic Bytes Packets Errors %
Transmit: 9252544 496 0 0
Receive: 170067878 155602 0 0
ATM Traffic Cells Errors %
Transmit: 508878 0 0
Receive: 3664628 0 0
DSL Link Errors
Collected for 3:58:30
Since Current Current Time Since
Reset 24-hr int. 15-min int. Last Event
ATM
Last Event
Cell Header Errors 705 705 1 0:08:25
Loss of cell Delineation 660 660 0 3:50:56
DSL
Link Retrains: 1 1 0 3:50:56
DSL Training Errors: 2 2 0 3:50:36
Training Timeouts: 0 0 0 0:00:00
Loss of Framing Failures: 2 2 0 3:50:56
Loss of Signal Failures: 2 2 0 3:50:56
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 2 2 0 3:50:56
Cum. Seconds w/Errors: 41 41 2 0:04:26
Cum. Sec. w/Severe Errors: 11 11 0 3:50:56
Corrected Blocks: 1712 1712 11 0:02:54
Uncorrectable Blocks: 715 715 2 0:04:26
DSL Unavailable Seconds: 83 83 0 3:50:19
1.64 Down UP 0.58 Ping 50.88 Best for ages Will it last Thank You
07-10-2015 5:04 PM
10-10-2015 11:48 AM
Uptime: 0 days, 1:22:28
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 650 / 1.900
Data Transferred (Sent/Received) [MB/MB]: 16,06 / 112,15
Output Power (Up/Down) [dBm]: 12,4 / 17,3
Line Attenuation (Up/Down) [dB]: 43,6 / 71,0
SN Margin (Up/Down) [dB]: 5,6 / 7,8
Chipset Vendor ID (Local/Remote): BDCM / BDCM
Loss of Link (Remote): -
Error Seconds (Local/Remote): 4 / 0
FEC Errors (Up/Down): 4.100 / 74
CRC Errors (Up/Down): 27 / 24
HEC Errors (Up/Down): 97 / 104
10-10-2015 12:49 PM
11-10-2015 10:09 AM
DSL Connection
Link Information
Uptime: 0 days, 20:24:24
Bandwidth (Up/Down) [kbps/kbps]: 747 / 1.679
Data Transferred (Sent/Received) [MB/GB]: 132,55 / 1,04
Output Power (Up/Down) [dBm]: 12,4 / 16,6
Line Attenuation (Up/Down) [dB]: 44,0 / 71,5
SN Margin (Up/Down) [dB]: 6,2 / 9,0
Loss of Framing (Local/Remote): 8 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 544 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 1.402 / 1.877
HEC Errors (Up/Down): 537 / 1.811
11-10-2015 3:56 PM
So what happened regarding the phone fault? All updates would be via Plusnet, Openreach don't contact end users directly (apart from the engineer phoning before they arrive).
11-10-2015 8:24 PM
17-10-2015 10:19 AM
Download Speed
1.56 Mbps
0 Mbps 2 Mbps
Download speedachieved during the test was - 1.56 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 1.75 Mbps
Upload Speed
0.49 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.49Mbps
Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
17-10-2015 10:21 AM
Link Information
Uptime: 0 days, 21:16:54
Bandwidth (Up/Down) [kbps/kbps]: 755 / 1.979
Data Transferred (Sent/Received) [MB/GB]: 228,30 / 1,99
Output Power (Up/Down) [dBm]: 12,4 / 16,8
Line Attenuation (Up/Down) [dB]: 43,9 / 71,5
SN Margin (Up/Down) [dB]: 6,3 / 5,7
Loss of Framing (Local/Remote): 26 / 0
Loss of Signal (Local/Remote): 4 / 0
Error Seconds (Local/Remote): 1.848 / 0
CRC Errors (Up/Down): 2.463 / 2.849
HEC Errors (Up/Down): 939 / 6.519
17-10-2015 10:31 AM
It would seem we now have a good result I hope it stays this way, but we have nearly been here before Thanks to all for the help We will see if this lasts
17-10-2015 9:01 PM
