Next to no broadband
- Next to no broadband
19-11-2015 7:58 PM
The router is connected but I have next to no broadband.
Can someone check the line for number XXXXXXXXXX and see if there are any faults please?
adie:green removed phone number as it's a public forum.]
Re: Next to no broadband
19-11-2015 8:07 PM
Have you done all the tests as per your thread a few months back. What exactly is next to no broadband ? please can you post a speed test and
the stats from your router.
20-11-2015 10:13 AM
20-11-2015 12:35 PM
I cannot post a speed test as the speed of my broadband is so slow or failing that the page simply won't load. Seeing the amount of disconnects - even today - is seriously worrying. Last night I changed to another router (BT Home Hub 4 to Plus.Net's standard router) and new Micro filter to try and improve performance and it seems like I'm still having a lot of issues.
Also I noted that there was maintenance across London this week so I am wondering if that has effected the stability of my line as this seem to have kicked off Wednesday. Seriously worried but I have done all I can (tried everything sensible) to try and resolve but will complete the only trouble shooter.
20-11-2015 12:38 PM
If you're still having issues I'd recommend finishing the troubleshooter here
https://faults.plus.net
20-11-2015 6:43 PM
It's not looking hopeful that this is going to be resolved any time soon.
Checked the router and has been another disconnect:
Your Plusnet adviser may ask you for the following information:
1 - Product name: Plusnet Router
2 - Serial number: N7150261B
3 - Firmware version: 7.273.1_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 0 days 00:00:19
7 - Data rate: 911/2315
8 - Maximum data rate: 904/3276
9 - Noise margin: 6.1/10.9
10 - Line attenuation: 27.0/48.0
12 - Data sent/received: 227.1K/297.4K
What work was carried out during the maintenance? It's too big a coincidence that it has been carried out and my line has gone out of the window. A tad frustrating!
21-11-2015 7:46 AM
This morning I have removed the plate and plug the cable in to the test socket and now the speeds have gone back to a far better stance as below:
5 - Mode ADSL
6 - Uptime: 0 days 00:11:25
7 - Data rate: 981/2144
8 - Maximum data rate: 1008/4148
9 - Noise margin: 5.2/11.2
10 - Line attenuation: 26.7/48.0
12 - Data sent/received: 7.8M/58.0M
I'm guessing the extension ports connected to the master socket are creating noise on the line :(. However the speed test came back with 0.3 mbps when i usually get 3.5 mbps. See attachment.
Still a problem.
Any suggestions
21-11-2015 12:29 PM
Could you run the diagnostic speed test and post the results please: http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
Also what is the current line speed reported by https://portal.plus.net/my.html?action=data_transfer_speed
21-11-2015 2:17 PM
21-11-2015 4:19 PM
Quote from: spoon Are any of the telephone extensions in use and if so do they have filters?
I did, but now the router is plugged directly in to the test socket so no extensions now. All phones and router have filters which I replaced just in case.
Still having the issue.
As requested:
Diagnostic speed test:
1. Best Effort Test: -provides background information.
Download Speed
0.19 Mbps
0 Mbps 2 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.19 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 2 Mbps
Upload Speed
0.63 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.63Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
Please visit the FAQ if you are unable to understand the test results.
Current Line Speed report:
Estimated line speed:
Current line speed:
2 Mb
23-11-2015 9:08 PM
Still no word from Plus.net and they have missed their deadline. All I wanted to know is that what they were doing - even an email would be nice.
Also did another speed test and this is how BTWholesale has changed its tune:
Download Speed
0.94 Mbps
0 Mbps 1 Mbps
Download speedachieved during the test was - 0.94 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-1 Mbps.
IP Profile for your line is - 1.01 Mbps
Upload Speed
0.64 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.64Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
I cannot believe that now all of a sudden when I am down to under 1/3 of my normal speeds it is pretending that everything is ok - so fully anticipating plus.net of wiping their hands of this one.
I'm cancelling as soon as possible. I've been with BT and TalkTalk before and whenever I have had problems they have had far better communication and response times. I'm heading back to them pronto.
03-12-2015 12:40 PM
BT Technician visited my property on the 02/12/15. Ran tests and determined that there was an issue on my line. Swapped me on a new line but my broadband is still dropping like no ones business.
I had to take a half day for this visit and now I'm being asked to arrange another visit. I don't have the holiday and weekend visits do not look likely so I'm at a loss as to how to resolve this.
If it is not an issue with my wiring in my flat not sure why I need to be involved for another visit. Couldn't BT Open reach attend the cabinet and call back to plus.net once the work is done to see what the results on my lines are?
08-12-2015 4:34 AM
Mode: ADSL_G.dmt.bis
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (1 dB): 10.8 6.5
Attenuation (1 dB): 48.0 26.6
Output Power (1 dBm): 0.0 12.8
Attainable Rate (Kbps): 3332 944
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 2375 947 0 0
MSGc (# of bytes in overhead channel message): 59 13 0 0
B (# of bytes in Mux Data Frame): 74 28 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 1 4 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.9966 0.9707 0.0 0.0
L (# of bits in PMD Data Frame): 602 239 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0 0 0.0 0.0
INP (DMT symbol): 0.00 0.00 0.0 0.0
Super Frames: 0 0 0 0
Super Frame Errors: 73145 0 0 0
RS Words: 0 1361805 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 202432 0 0 0
OCD Errors: 218 0 0 0
LCD Errors: 218 0 0 0
Total Cells: 7478408 3050089 0 0
Data Cells: 543226 80218 0 0
Bit Errors: 0 0 0 0
Total ES: 1348 0
Total SES: 1348 0
Total UAS:
