Neww fttc install
- Neww fttc install
Neww fttc install
03-10-2014 7:56 PM
Hi
Fttc broadband was installed this morning at 9 am. Just got home and logged in etc and did a speed test and got this
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
1.75 Mbps
0 Mbps 77.44 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.75 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload Speed
2.91 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 2.91Mbps
I am at the moment slower on download as than yesterday on a 2 meg adsl conection...any ideas what I need to do
thx
FAQ
Download Speed
1.75 Mbps
0 Mbps 77.44 Mbps
Upload Speed
2.91 Mbps
0 Mbps 20 Mbps
thx
Message 1 of 3
(696 Views)
2 REPLIES 2
Re: Neww fttc install
03-10-2014 8:02 PM
This may be the problem
What does it say for Current Line Speed
If it is your previous ADSL figure - 2Mbps approx then it needs updating
I suggest phoning in and asking for the Plusnet profile to be updated
If it says 77.4Mbps then go to this http://192.168.1.254/cgi/b/bb/?be=0&l0=2&l1=-1 and click on disconnect then connect and that should fix it
Message 2 of 3
(418 Views)
03-10-2014 10:30 PM
Thanks Jim....phone call did the trick, now up and running at full speed
thanks
thanks
Message 3 of 3
(418 Views)
