Newbie with router problem
- Newbie with router problem
09-05-2015 5:58 PM
Hi all. Just set up router after moving over to Plusnet from BT.
Connection all seemed to go fine and able to use laptop and printer but my router is winking and blinking and flashing at me.
It is the WPS light and it's driving me nuts - is there an easy solution to this please?
Many thanks for your help and tolerance for an IT idiot....age 65
Cheers, Maura.
Message 1 of 2
(465 Views)
1 REPLY 1
Re: Newbie with router problem
09-05-2015 8:01 PM
If you're using the Plusnet 2704n router, the following may help:
http://www.plus.net/support/broadband/hardware/plusnet-2704n-wireless.shtml
Message 2 of 2
(275 Views)
