New user joining quick question
Calam
I am having plus net Broadband starting tomorrow I have received the router from plusnet. But plan to use my own tplink D20 is it OK to use mine straight away or do I need to setup up the plusnet router.
9 REPLIES 9
Gel
Aspiring Champion
Fixes: 29
Re: New user joining quick question
You can use either; the PN one is dual band capability giving you faster speeds if you have compatible devices.
Calam
Ok thanks I received the plusnet 2704n router (think that the name) is this dual band?
Fixes: 49
The following links should help. The first gives you the settings required to use your own equipment. The second gives details of PlusNet routers.
https://www.plus.net/help/broadband/broadband-connection-settings/
https://www.plus.net/help/broadband/router-setup-guides/
Anoush
Aspiring Hero
Fixes: 139
Hi there @Calam first of all a warm welcome to the community forums.
The Plusnet Hub Zero (2704N) isn't a dual band router I'm afraid. The WiFi technology built-in is Wireless-N. As long as your router supports PPPoA and ADSL2+ it should work with Plusnet.
Once you receive confirmation that your broadband service has gone live, you'd need to configure it using the settings here: https://www.plus.net/help/broadband/broadband-connection-settings/
I hope this helps.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Mustrum
Fixes: 77
And no, the 2704 is not dual band, only the Hub 1, which comes with fibre connections is dual band.
Calam
Thanks everyone for your help
Calam
All up and been 24hrs all good just one very minor question when I run speedtest. Com
It said that BB suppliers called BT Global services?
Gel
Aspiring Champion
Fixes: 29
Mustrum
Fixes: 77
It's just one of the problems that happen when PN expand their network and borrow/pinch ip addresses from other parts of the BT group, before everything catches up o the correctly named owners.
Although @Gel is correct BTGS and Openreach are different BT Divisions.
