New to plusnet and speed has dropped from 8mb to 2.5mb!
- New to plusnet and speed has dropped from 8mb to 2...
27-01-2014 8:11 PM
Anyone got any ideas, suggestions? When i was with sky i happily got 8mb ave. on downloads with no issues. only thing that has changed is the modem and moving to plusnet and know my service is no where near as good!
not happy
not happy
Message 1 of 5
(801 Views)
4 REPLIES 4
Re: New to plusnet and speed has dropped from 8mb to 2.5mb!
27-01-2014 8:14 PM
Hi there.
I've looked over your line and I can't see any issues.
You should be getting around 8.8mbps from what I can see.
Can you run through our troubleshooter using the link below?
http://faults.plus.net
Message 2 of 5
(494 Views)
27-01-2014 8:21 PM
I don't have a spare router to try nor a standard telephone. its a dect one so can't pick it up to listen for dialing tone
Message 3 of 5
(494 Views)
27-01-2014 8:22 PM
are those results wired or wireless as I assume that you changed routers on the move from Sky
Dect one should still allow you to hear the dialling tone once you press the button on the handset
Message 4 of 5
(494 Views)
27-01-2014 8:31 PM
See what the http://speedtest.btwholesale.com/ says also click Click further diagnostic to get line profiles.
Then see if they match plusnet's in member centre control panel
Message 5 of 5
(494 Views)
