New to plus net and having a few issues - Hope they can be fixed
- New to plus net and having a few issues - Hope the...
05-07-2011 7:03 PM
Not a good start, went live on friday and having loads of drop outs and speed drops, peeps at plusnet looking into it, i can see from this forum the customer service is good, so hopefully it will get sorted soon.
results from bt speedtester
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
81 Kbps
0 Kbps 250 Kbps
Max Achievable Speed
Download speedachieved during the test was - 81 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :2784 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Router stats
--- System Information ---
Vendor: Linksys
ModelName: WAG320N
Firmware Version: 1.00.12 , 2010-03-22T10:51:43
Boot Version: 1.06
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 0/38
DSL Status: Showtime
DSL Mode: G.DMT
DSL Channel:
DSL Upstream Rate: 448 Kbps
DSL Downstream Rate: 2784 Kbps
Down up
DSL Noise Margin: 15.4 dB 19.0 dB
DSL Attenuation: 52.0 dB 30.0 dB
DSL Transmit Power: 18.5 dBm 12.3 dBm
Its a brand new phone line, ( inc the cables from the pole as there was no line in the flat), plugged into test socket, nothing else plugged in, tried 2 filters and same issue, very annoying.
Hope this gets resolved soon.
Running the extra package with the add-on to keep the speed up.
Re: New to plus net and having a few issues - Hope they can be fixed
05-07-2011 9:40 PM
Could be that your line is settling in, I have just been upgraded and have had a few drop outs as they find the best speed for the line.
Wait and see if it settles, if it doesn't then the people at PlusNet will sort things for you, they are very helpful.
Good luck,
Bllinky
05-07-2011 10:07 PM
Unfortunately I don't think Plusnet can raise a fault until the 10 day training period has finished.
There is one thing you can check however and that is the quiet line test - dial 17070 option 2 - the line should be quiet.
If it is noisy (crackles etc) try it it with just the phone connected and and then add the result to the existing ticket as then they can raise a voice fault immediately.
If it is quiet then you will need to let the broadband fault process take it's normal course
06-07-2011 6:14 AM
06-07-2011 10:36 AM
I hope the training period settles it for you though it definitely looks intermittent at the moment. Is the router in the master socket with no extension cables, and are all other items plugged into the phone line filtered? Either way we'll get the fault raised as soon as we can if it doesn't settle down.
06-07-2011 4:36 PM
What does interleaving do ? and is it really going to get me back up to the full speed i should be getting. at the moment the ip profile is set to 135k,
Surely there must be a fault on the line somewhere, is that being investigated ? or was turning interleaving on the answer ?
Any feedback would be gratefully received.
12-07-2011 5:09 PM
PLEASE PLEASE SORT MY BROADBAND - Its getting very frustrating
12-07-2011 7:30 PM
Thanks for your time earlier. I've managed to get it up to 3000k, so you should see that in the next 15 mins when it goes through. It doesn't look too bad right now but we'll have to see how it performs. In the meantime, don't make any changes to your set up, that way we'll have a better idea of what's going on.
Jojo
12-07-2011 8:05 PM
Thanks again and have a good evening
12-07-2011 8:51 PM
12-07-2011 10:24 PM
13-07-2011 8:56 AM
Thanks for your time. We'll confirm the appointment time via text.
Jojo
13-07-2011 12:14 PM
Thanks for your help !!
13-07-2011 12:40 PM
15-07-2011 12:13 PM
engineer came out today and found a fault in the cable from the pole to my house and he replaced it. he suggested i get the snr reset, and my profile will need raising, can this be done please
thanks
hopefully it will be all good now
Thanks again
