New to +net 4MBS by day and 0.4 every evening - help!
- Re: New to +net 4MBS by day and 0.4 every evening ...
12-02-2016 9:10 PM
Re: New to +net 4MBS by day and 0.4 every evening - help!
13-02-2016 12:46 AM
Quote from: MeteorUK Joined +net on Monday after 3 happy years at TT. I have a Sky netgear dg934g router.
Daft question have you updated the username and password to your PN details?
We do see this a lot with sky routers that are locked.
13-02-2016 8:22 AM
13-02-2016 10:01 AM
You said " I have only tested the speed between 12.30 and 13.30 when always get 4MBS - which I am happy with."
Therefore you must be connected and must have already entered the user name and password.
Do you know how to get the stats from the router - connection time /errors/ SNRM/ attenuation and so on.
Is the router left switched on all the time? Were you with Sky previously and what speeds did you get.
13-02-2016 11:01 AM
Quote from: MeteorUK . What is my username and password and where do I need to enter it?
Your username is the one you chose when you joined Plusnet, this needs to be entered into the router as the login name for the DSL connection, but with the suffix of "@plusdsl.net". It should be detailed if you login to your Plusnet account using this link ... https://portal.plus.net/my.html?s=0&action=refresh_browser ; If that link doesn't work, login and look for Connection Settings, then Connection Details. I'm not familiar with that Netgear router, which seems to be a special model specifically for Sky, but if you're not clear where to enter these details in the router, post a couple of screenshots and someone will be able to advise.
I found this article on how to convert a Sky DG934 to use standard software ... http://www.kitz.co.uk/routers/skyDG934.htm ; ... at your own risk of course!
13-02-2016 6:22 PM
13-02-2016 6:38 PM
13-02-2016 6:40 PM
13-02-2016 6:48 PM
13-02-2016 6:55 PM
But : Why don't you get a PN router? They are free, you only pay for the postage , and they work out of the box; you do not have to do anything to set it up. (Before anyone jumps in with a clever answer - I know there are plenty of reasons to NOT consider a PN router for the more technically minded! )
mav:quote
13-02-2016 8:43 PM
