New to fibre but download speeds slower than ADSL
- New to fibre but download speeds slower than ADSL
06-10-2011 11:09 AM
Fibre installed yesterday.
Do I need to raise a call or do something else?
Re: New to fibre but download speeds slower than ADSL
06-10-2011 11:32 AM
Jojo
06-10-2011 11:42 AM
06-10-2011 11:51 AM
06-10-2011 12:30 PM
or you downloading at 232kb sec (or so) which is just over 2mb ?
06-10-2011 1:00 PM
06-10-2011 5:56 PM
I'd have thought that Plusnet would have realised this before sending me to that site.
http://www.mybroadbandspeed.co.uk/ does work however and responds with the following....
Download Speed: 22206 kbps (2.78MB/s)
Upload speed:1616 kbps (202kB/s)
After reading these forums it appears that Plusnet should have carried our a reset of my line once I had fibre installed which I am guessing has not happened.
06-10-2011 6:08 PM
My broadbandspeed does not tell us the sync speeds and IP Profile.
06-10-2011 6:22 PM
06-10-2011 6:23 PM
Test show...
> Download speedachieved during the test was - 23698 Kbps
For your connection, the acceptable range of speedsis 16244-23206 Kbps .
Additional Information:
IP Profile for your line is -23206 Kbps
06-10-2011 11:31 PM
07-10-2011 6:34 PM
09-10-2011 12:19 AM
Is it just confusion between 2.5 megabit connection and a download rate of 2.5 megabytes per second?
All the tests are showing quite a healthy connection, 2.78MB is roughly 22Mb
10-10-2011 10:09 AM
If he's on Fibre Value (like i am until 5 days time), then you'll find between 8am to Midnight, your line is 2mb........ (ok, so web browsing runs at 22mb or faster), but anything else runs at 2mb....
So makes sense what he's saying
10-10-2011 10:12 AM
