New subscriber, no braodband
bevs
I have been a Plusnet customer previously, with no problems whatsoever, however I recently moved and have signed up with Plusnet again for a phone and broadband. As I had a router I didn't see any point in getting a new one. Everything went 'live' yesterday after waiting a week since the line was installed, green lights are showing for broadband and wifi, red light for internet. So effectively nothing is working. The router is a TG582n.
The Plusnet website is shocking as you cannot find a telephone number to contact a technical person, the 'contact us' buttons on the website are inactive. Eventually when I did find a number, got through to be told the waiting time is about 45 minutes. The Troubleshooter also didn't help to identify my problem.
I would like some help PLEASE.
Fixes: 62
Re: New subscriber, no braodband
There are two possible causes which spring to mind
The router settings - account login username@plusdsl.net and account password aren't correct
The account hasn't been activated on the Plusnet side
Fixes: 162
The account is definitely active, the line seems to be connected at a very good speed too.
However the authentication details are set wrong, they seem to have your old username in still as Oldjim suggested.
I may be able to sort that from here, but it'll need a factory reset of the router from your side to push the new details through.
 Chris Parr
 Plusnet Staff
bevs
Hi Chris, have you been able to resolve anything on your side? Let me know what I have to do for the factory reset, if that is needed.
Fixes: 162
On the back of the router there is a pin hole, you need to use something to push this in for around 10 seconds and then just wait for 5-10 minutes. I'm hopeful this will get you online.
 Chris Parr
 Plusnet Staff
bevs
Thanks so much Chris, that appears to have worked. Can't tell you how happy I am 
Fixes: 205
Glad to hear you're back online.
 Matthew Wheeler
