New router setup
- New router setup
New router setup
16-12-2013 2:10 PM
Plusnet has been failing in delivering my router so I went and bought a router today but am having difficulty setting it up. Was hoping to get some expert advice. It's a TP Link N600. Did everything like the quick setup etc but it still doesn't connect can someone please please walk me through it.
Re: New router setup
16-12-2013 3:05 PM
Sorry to hear about the issue with your router deliver from us.
Re the new router have you checked that the username has been entered with the correct @plusdsl.net suffix?
I ask as there are no failed connection attempts showing up on our logs.
Adam
16-12-2013 3:36 PM
Quote from: jahedur It's a TP Link N600.
The model number would help - there are a few N600s
16-12-2013 4:29 PM
16-12-2013 4:57 PM
So far I've set it up the user as xxx@plusdsl.net but nothing.
Thanks for the help in advance guys.
16-12-2013 9:35 PM
Under network/wan you need:
VPI = 0
VCI = 38
connection type = PPPoA (though PPPoE can be used)
I would set the service name to Plusnet, but it is only an identifier.
The rest you have probably already setup (username/password ...).
17-12-2013 12:18 AM
Based on Adam's reply you are on the ADSL service?
If yes to above you have entered both the username & password?
Bearing in mind this is an ADSL & Fibre capable router have you plugged the modem cable into the correct port = the ADSL port and not the EWAN port? ~ for the record it is possible to plug the RJ11 terminated modem cable into an RJ45 EWAN/Ethernet port!
Assuming it has the DSL light on the front what happens with it all wired up...............does it flash, solid colour (is so what colour?) NB If the light is off/not showing then my comment about the cable port you have plugged into is quite relevant
HTH and best of luck
17-12-2013 9:46 AM
And the current set up I have is the DSL line from the socket connected to the open reach modem and a Ethernet running from the open reach modem to the tplink router. And from there an Ethernet running to my computer.
Following the troubleshooter on the plusnet I was able to however get internet when I bypassed the router and connected straight from the openreach modem not sure if that means anything???
17-12-2013 10:05 AM
17-12-2013 10:27 AM
I fail to see the advantage of these devices vs routers, even as a stop-gap whilst waiting for fibre to be available.
17-12-2013 1:23 PM
17-12-2013 7:00 PM
17-12-2013 8:14 PM
