New router questions
morgan2476
I have stopped using the Thomson router which I received from PN and I now have Net gear N150 Router.  Couple of questions
1. How do I check how secure the wireless is?
2 Every now and again I get a pop up window asking me to dial up broadband, how do I solve this problem?
bluewhale
Re: New router questions
2. if using ie go to tool -> options
then on the form click on the connections tab
you should see a set of radio button select the never dial a connection
not sure about 1. apart from making sure you are using the correct security settings preferably wpa2 and good passkeys
morgan2476
Thanks for that bluewhale that problem is now sorted
Regards
