New router or powerline?
- New router or powerline?
30-09-2014 11:17 AM
I now have my new fibre connection working at 30+mb across the house. Streaming over wifi to our Panasonic smart TV suffers from lag with frequent buffering interludes. The TV shows a three out of five bar wifi connection. Should I invest in a new router to get a stronger wifi signal or would powerline adapters be a better way to go?
Message 1 of 5
(918 Views)
4 REPLIES 4
Re: New router or powerline?
30-09-2014 12:38 PM
It really depends on how much you want to spend. With the powerline adaptors you could install one by the TV.
Message 2 of 5
(554 Views)
30-09-2014 1:15 PM
Power line adapters put Ethernet where you want it. Ethernet is always going to be faster than wifi. TV over wifi will also hammer other wifi connected devices.
I use Devolo units and have found them to be faultless.
Message 3 of 5
(554 Views)
30-09-2014 1:16 PM
I went the powerline route, mainly because I also have a Youview box and another PVR which don't have wifi. The powerline (Solwise 200AV) feeds a cheapo switch (Tenda) behind the telly. Alternatively you can get a powerline adapter with 3x ethernet ports built in
Message 4 of 5
(554 Views)
30-09-2014 6:19 PM
Is a flat Ethernet cable tucked under carpet edge another option worth thinking about instead of the power line adaptors?
I've recently ditched the power line adaptors & gone the flat Ethernet cable route during a period of re decoration.
Message 5 of 5
(554 Views)
