New member, router configuration settings.
- Re: New member, router configuration settings.
09-07-2013 1:48 PM
Hello All,
I was advised by the customer services team to look on this forum for the settings i need to configure my router.
I'm moving from BE. I've decided not to use the standard issue modem provided by plusnet (speedstep/technicolor i believe) and use my own instead.
I searched the forum for the settings i need to use to have it setup when my service is enabled but i couldn't find it.
I use a Netgear DGND3300 (netgear settings a
On BE, my settings were as follows:
Multiplexing: LLC
VPI/VCI 0/102
Encapsulation: PPPoA
Username and passwords were blank
get ip automatic
Manual DNS configuration (Open dns)
Are there equivalent settings for the plusnet service that i could have at hand to have my modem configured at the time of activation next week?
Thank you in advance.
Multiplexing: LLC
VPI/VCI 0/102
get ip automatic
Message 1 of 4
(888 Views)
3 REPLIES 3
09-07-2013 1:57 PM
Hi "ojconcentrate" - Welcome to the forum
You don't much setting up to get your DGND3300 running -
Encapsulation = PPPoA
Multiplex = VC
VPI = 0
VCI = 38
Your login name as shown in the Plusnet "Member centre" (login required) - Connection Details
Your password
I would advise sticking with your DNS configured for OpenDNS and or GoogleDNS
Set everything else to default, dynamic, or auto, and it should connect.
Good luck
I think it was a bit of a cheek for customer services not have told you your basic connection settings and then fobbed you off with asking here for help just because you are using your own modem/router !. You are VERY welcome to ask as much as you like here on the forum, but I think customer services could have tried a little harder !. Perhaps the person involved needs 'recalibrating' ?
Multiplex = VC
VPI = 0
VCI = 38
Your password
Good luck
Message 2 of 4
(470 Views)
09-07-2013 2:43 PM
The generalised settings can be found in the PN Help & Support pages here http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Message 3 of 4
(470 Views)
09-07-2013 3:29 PM
that is exactly what i was looking for. Thank you all and I look forward to the service being activated.
Message 4 of 4
(470 Views)
