New master socket now BB speed crashed
- New master socket now BB speed crashed
07-07-2012 12:39 PM
I have changed micorfilter, it's pluged into test socket, I have even changed the router and still get the same results.
Plusnet are trying to cure the problem, but it seems to take forever this has been ongoing since Thursday 28th June!!!!
Has anyone had the same problems, and if so how did they fix it???
Re: New master socket now BB speed crashed
07-07-2012 12:43 PM
Speeds, attenuation and noise margin
07-07-2012 12:50 PM
Profile: WBC 160K - 288K Medium delay (INP 6dB Downstream, 448 Medium delay (INP 2) 9dB Upstream (ADSL2+) bRas:
Provisioned: WBC MAX24 mb/s (ADSL2+ Annex A) Standard Stability, Auto Interleaving, Enhanced Care, Elevated, 448kbit/s Upstream
WP Profile: Generic Speed 250 No Time Out adjusted to 5500
Tags: Estimated ADSL2+ broadband line speed of 5.5Mbps; typically the line speed would range between 4.5Mbps and 9Mbps
Sync Rate: 283
Fault Threshold Rate: 1612
xDSL Status Test Summary
Sync Status: Circuit In Sync
General Information
NTE Status:
NTE Power Status:
PowerOn
Bypass Status:
Upstream DSL Link Information
Loop Loss: 32.5
SNR Margin: 19
Cell Count: 1166
Speed: 440
Downstream DSL Link Information
Loop Loss: 55.5
SNR Margin: 6
Errored Seconds: 0
HEC Errors: 0
Cell Count: 1378
Speed: 440 283
Maximum Stable Rate (KBPS): 2016
Fault Threshold Rate (KBPS): 1612
Mean Time Between Retrains (Seconds): 31
Mean Time Between Errors Upstream (Seconds): 182
Indicative Line Quality: R
Mean Time Between Errors Downstream (Seconds):
Initializations: MIN:0 | MAX:92 | AVG: 99 (Times in an hour)
Copper: Pass
TAM: DNR
[EPP30] An LTB issue has been identified with poor Indicative Line Quality (RED ILQ).
Resolution/Recommendation: Please confirm all CP and End User checks have been completed. KBD tests indicate no BTW network fault. This is a CCSFI enabled outcome.
jim:green attempted to sort out formatting - I hope I got it right mod:end
07-07-2012 1:02 PM
Were those results from the test socket and can you post the current stats from the router using the test socket
07-07-2012 1:21 PM
07-07-2012 1:26 PM
If you have it will be reported to BT as a line fault and acted on
I appreciate that those results are from the test socket but are you still using it and, if so, can you advise what the router is currently reporting
07-07-2012 2:30 PM
Uptime: 0 days, 5:33:33
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 444 / 288
Data Transferred (Sent/Received) [MB/MB]: 14,02 / 83,68
Output Power (Up/Down) [dBm]: 12,9 / 0,0
Line Attenuation (Up/Down) [dB]: 32,5 / 55,5
SN Margin (Up/Down) [dB]: 21,5 / 6,6
Loss of Link (Remote): -
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 0 / 13.783
CRC Errors (Up/Down): 9 / 6
HEC Errors (Up/Down): 7 / 3
jim:green formatted mod:end
07-07-2012 4:30 PM
One thing you could just try is to check the tightness of the screw connectors where the incoming wire is connected to the back plate
08-07-2012 10:57 AM
08-07-2012 5:42 PM
Did you make Plusnet aware that you'd had a phone fault which I presume is now fixed? If so, it's ridiculous that the line has not been un-banded.
IF the phone line fault is fixed - add to the ticket details about the fact that you had a phone fault which has been fixed and request the line is un-banded. Then phone up Plusnet and point then at the ticket and request they do so asap. Make sure you speak to a supervisor otherwise it could be going round in circles if an in-experienced CSC agent is busy on his script led rhubarb.
08-07-2012 6:17 PM
The downstream noise margin is 6.6dB and if it was banded I would have expected that it would be much higher
08-07-2012 6:51 PM
Quote Profile: WBC 160K - 288K Medium delay (INP 8 )
That means it's banded. Perhaps the phone line fault is still not fixed properly and that's why the margin is still around 6dB, but it's definitely banded.
Edit: I've edited my previous post to qualify the ticket addition - IF the phone line fault is fixed
09-07-2012 4:27 PM
I see the faults team have reset the line. There's no banding at the moment but the sync rate is still very low. I'll see if I can get someone to take a look.
Jojo
