New laptop-connection
dennisb66
I am trying to connect a new laptop to my wireless router,my router is a Thomson TG585v7,I assume that the WEP on the back of it is the security ID that I use to set up the connection,can you please confirm as I am having problems connecting.
Thanks Dennis
kosymodo
Re: New laptop-connection
Yup, that's right.
What's the problem you're getting?  Any error messages?
dennisb66
Thanks Kosy,  yes I get a message "Network security Key Mismatch". I'm wondering if i could have made a mistake on the set-up,  ex.o instead of 0.
    If so next question is how do i delete and then re-enter details.
dennisb66
SORTED Grin  Yes I boobed on initial install.Doh Embarrassed
