New laptop-connection
- Re: New laptop-connection
14-10-2011 12:47 PM
I am trying to connect a new laptop to my wireless router,my router is a Thomson TG585v7,I assume that the WEP on the back of it is the security ID that I use to set up the connection,can you please confirm as I am having problems connecting.
Thanks Dennis
Thanks Dennis
Message 1 of 4
(752 Views)
3 REPLIES 3
14-10-2011 1:29 PM
Yup, that's right.
What's the problem you're getting? Any error messages?
Message 2 of 4
(354 Views)
14-10-2011 1:41 PM
Thanks Kosy, yes I get a message "Network security Key Mismatch". I'm wondering if i could have made a mistake on the set-up, ex.o instead of 0.
If so next question is how do i delete and then re-enter details.
Message 3 of 4
(354 Views)
14-10-2011 3:34 PM
SORTED Yes I boobed on initial install.Doh
Message 4 of 4
(354 Views)
