New installation - red internet light
Bagpuss
I'm having no luck in getting online with my new router. I've reset it twice but the internet light is constantly on red. I can't get through on the phone. Please will someone at Plus.net help?
2 REPLIES 2
Alex
Fixes: 13
Re: New installation - red internet light
Are you using a PlusNet Hub One?
Have PlusNet confirmed your service should be active now?
If so, try disconnecting everything from your line and see if the router performs any better from your master socket.
adamwalker
Fixes: 206
Hi there, I've just checked your account and can see you've since got the router connected.
I've just tried calling to make sure but I'll try again tomorrow.
 Adam Walker
