New install gone live :)
- New install gone live :)
05-07-2011 6:07 PM
Hiya,
My new line went live today, earlier than expected Thank you.
I've got a quick query .. In the member centre it shows the following:
My IP Profile on speedtester.bt.com say's the following:
I've got the pro-addon but the fastest I can seem to get anything to come down at is 250kBs (however if I switch my internet connection to use my TalkTalk line I can get the same file at just under 1Mbps, line terminates at the same face plate etc)
Is 250kbps the fastest I can expect with my new line? unless I'm mistaken I appear to be getting speeds inline with your traffic management rather than line speed as stated in your pro-addon information.
Thanks in advance.
Quote Estimated line speed:
7Mb (Accurate to within +/- 1Mbit) - Checked on 2011-06-30 20:17:17
Current line speed:
7.15 Mb
Quote Download speedachieved during the test was - 1837 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :7936 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
Thanks in advance.
Message 1 of 2
(517 Views)
1 REPLY 1
Re: New install gone live :)
05-07-2011 6:39 PM
nevermind answered my own question:
1800 Kbps is 225 kB/s
Or 1.8 Mbps ::: 0.22 MB/sec
Message 2 of 2
(225 Views)
