New home ADSL
edwardw
New home ADSL
Just got ADSL connected in my new property - no fibre frown
anyway, seems really slow...
can someone look at these stats?
System Up Time 00:28:09
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 15335 15506 0 2653 11437 00:19:33
LAN 10M/100M 1799 2050 0 442 177 00:28:04
WLAN 11M/54M 18156 18581 0 15173 3745 00:15:50
ADSL Link Downstream Upstream
Connection Speed 6001 kbps 439 kbps
Line Attenuation 36 db 9.5 db
Noise Margin 6 db 24 db
33 REPLIES 33
Jaggies
Re: New home ADSL
The downstream speed looks really poor for your line attenuation. According to the Kitz Speed Calculator your downstream on ADSL Max should be 7424 and on ADSL 2+ it should be 11168 - you're only showing 6001.
It's impossible to tell which you are on as your upstream shows as 439, however I suspect you are on a capped ADSL2+ with perhaps a banded profile.
Can you run the BT Wholesale speedtest (including "Further diagnostics") and paste the result in to your reply?
edwardw
Re: New home ADSL
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
edwardw
Re: New home ADSL
Spoke to PN, they say the order isnt complete yet so i shouldnt be able to connect! 😕
Web was slow this morning, seems to have picked up a little now, done another resync:
Modem Status Connected
DownStream Connection Speed 7398 kbps
UpStream Connection Speed 439 kbps
Wonder why im still on a slow upload 😕
Jaggies
Re: New home ADSL
Keep trying the Further Diagnostics on the BTW test - if you can get a result it may help pinpoint the issue.
adamwalker
Fixes: 221
Re: New home ADSL
The order completed this morning so I've been able match the speed profile for your account to BT's so let us know how things are with this today.
Adam
 Adam Walker
jelv
Fixes: 10
Re: New home ADSL
Quote from: edwardw
Because after how ever many years it is since 21CN was launched Plusnet have still not fixed their system to order new connections uncapped. You need to ask them to uncap it.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
edwardw
Re: New home ADSL
Quote from: _Adam_Walker_
Adam
Thanks, Not at home until thursday but shall test then Smiley
edwardw
Re: New home ADSL
Adam
Hi..
Unfortunately im still on a 439kb upload Sad
Im going to ring tech support see what advice they can offer.
adamwalker
Fixes: 221
Re: New home ADSL
No need, I've just raised order 2-84686692055 to uncap the upstream tomorrow.
Adam
 Adam Walker
edwardw
Re: New home ADSL
Ah, you said that whilst i was on hold Smiley
Is it basically a product change then?
So you supply initial orders on a capped product then have to req a change with BTOR to change it?
edwardw
Re: New home ADSL
Adam
Also adam, is it possible to be placed on a 3db noise margin please?
orbrey
Re: New home ADSL
We can request that but it'll have to wait until Monday I'm afraid - we can't do it while there's an order going through.
adamwalker
Fixes: 221
Re: New home ADSL
No worries, that's why it's worth waiting to see if we reply first Wink
That's right yes, at present the default upstream for an ADSL2+ connection with us is 448kbps but we're happy to uncap that upon request.
Yep, happy to do that looking at how you're line is performing. That should take effect within the next couple of hours.
Adam
D'oh looks like myself and Matt were ready to post at the same time, I've let him know that we can actually submit an SNR reset when an order is pending Wink
 Adam Walker
edwardw
Re: New home ADSL
Thankyou Smiley
