New fibre very slow download speed
fp
The BT engineer came this morning (just) and installed my new fibre connection  - the 79mbps version which is my predicted speed.  Well done PN.
However the download speed is less than ADSL <7mbps and currently around 4mbps.
Strangely the upload speed is ~18mbps
Help.
Plusnet Alumni (retired) LinnPlusnet
Re: New fibre very slow download speed
Hi there fp,
I can see that the order to provide you with FTTC has completed and you should now be receiving the faster speeds. Can you try running a test here: http://speedtest.btwholesale.com/
fp
Thanks Linn K
Download 75.03 Mbps
Upload 17.29 Mbps
latency 20.13 ms
Looking good.
