New fibre install
bart6622
New fibre install
Hello,
Is it possible for a member of the Plusnet staff to check my line I have had fibre installed this morning and my estimated speed is 66 but I am only currently getting 28-30.
Thank you
Acassim
Re: New fibre install
Hi bart6622,
Glad to hear you're up and running with the fibre!
Just looking at the details on your account, it seems that the speed was updated on our side recently so could you check that you're getting the correct speed now?
Also, please be sure to test this while wired into the router as you may see a slower speed when testing via a wireless connection.
Thanks!
bart6622
The speed seems to be very unstable last night between 1800-1845hrs it was below 1mbps then it went up to 30-34, this morning it is at 7-9mbps surely this can't be right?
bart6622
Could it be the router?
I have noticed that the wifi signal drops down a bar every now and then and I am 10 metres away from the router.
bart6622
Speed Test at 1238hrs
Ethernet
Ping-10ms
Download-66.73mbpd
Upload-17.61mps
Speed Test at 1243hrs
Wireless
Ping-27ms
Download-14.38mbps
Upload-15.08mbps
Both tests were carried out using the same speed checking service, do I need to upgrade my router as 99% of the devices we use are wireless?
Plusnet Staff
Plusnet Staff
Fixes: 5
It's probably worth changing the Wireless Channel as shown here: http://www.plus.net/support/broadband/hardware/technicolor-582n-wireless.shtml
I'd advise using either channels 1,6 or 12.
Chris Pettitt
Cloud Environments Engineer
bart6622
Thanks for the reply
I was on channel 6 anyway but here are the results:
Channel 1
Ping-115ms
Download-12.74mbps
Upload-10.16mbps
Channel 12
Ping-21ms
Download-29.37mbps
Upload-18.12mbps
And then back to channel 6
Ping-19ms
Download-27.31mbps
Upload-17.46mbps
I have noticed that the wifi strength signal keeps dropping down a notch but the router is probably less than 10 metres away
Plusnet Staff
Plusnet Staff
Fixes: 5
Would you be able to get hold of another router to test with?
Do you get similar results on other Wireless Devices?
Chris Pettitt
bart6622
Not unless I went out and purchased a new router.
Wireless speeds are the same throughout.
Plusnet Staff
Plusnet Staff
Fixes: 5
I've sent out a replacement to see if it's any better. Your Wireless shouldn't be that bad from just 10 metres away.
Let me know how you get on.
Chris Pettitt
