New fibre connection speed
kenrui
Hey guys,
Please see ticket #82676208
Basically I have the same issue as digitalfixer65 had here: http://community.plus.net/forum/index.php/topic,124499.0.html
My download speed is the same as before the upgrade to fibre whilst the upload is much greater.
Could you please take a look to see if it's as easy to fix?
Thanks.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: New fibre connection speed
Hi kenrui,
I'm just taking a look now for you.
Chris Pettitt
Cloud Environments Engineer
Plusnet Staff
Plusnet Staff
Fixes: 5
That should be sorted now if you restart your router Smiley
Chris Pettitt
kenrui
Awesome, thanks Chris I'll do so ASAP.
kenrui
Thanks Chris, I've restarted the router and the speed is much much better!  Grin
All the best!
Plusnet Staff
Plusnet Staff
Fixes: 5
Awesome Smiley
Chris Pettitt
