New fibre connection speed
- Re: New fibre connection speed
12-03-2014 1:57 PM
Hey guys,
Please see ticket #82676208
Basically I have the same issue as digitalfixer65 had here: http://community.plus.net/forum/index.php/topic,124499.0.html
My download speed is the same as before the upgrade to fibre whilst the upload is much greater.
Could you please take a look to see if it's as easy to fix?
Thanks.
Thanks.
Message 1 of 6
(873 Views)
5 REPLIES 5
12-03-2014 2:05 PM
Hi kenrui,
I'm just taking a look now for you.
Message 2 of 6
(561 Views)
12-03-2014 2:06 PM
That should be sorted now if you restart your router
Message 3 of 6
(561 Views)
12-03-2014 2:10 PM
Awesome, thanks Chris I'll do so ASAP.
Message 4 of 6
(561 Views)
15-03-2014 4:55 PM
Thanks Chris, I've restarted the router and the speed is much much better!
All the best!
All the best!
Message 5 of 6
(561 Views)
15-03-2014 10:40 PM
Awesome
Message 6 of 6
(561 Views)
