New customer having issues please advise
- New customer having issues please advise
Re: New customer having issues please advise
20-03-2015 3:53 PM
That disconnection today was me running a line test. I'd like to monitor a little longer before we do anything further.
20-03-2015 11:10 PM
21-03-2015 8:44 PM
Also what profile am I on now?
22-03-2015 10:25 AM
Unless your sync speed changes (ie. there's a disconnect or test or reboot) your profile won't change.
It's very simple to check yourself by running the BTw Performance test (DON'T REBOOT, ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
The results should give you the IP Profile.
You can also check that your Current Line speed (Login required) matches (it's rounded down to the nearest 100kbps).
If for some reason the Diagnostic part of the BTw Speedtest fails (post that fact here), check the sync speed from the 2704n stats (called data rate iirc) - the profile on a 21CN connection is 88.2% of that figure.
22-03-2015 3:49 PM
While we are waiting here is the summary of this thread so far (correct me if im wrong):
Faults - Rectified Loop Fault, Lower Sync Speed
Fix Solutions - New Phone Socket, New Joints on DP, New D Side cable pair
22-03-2015 10:39 PM
The final decision will be Tony's, he may elect to leave it until the fault shows again as then there might be a better chance of finding it.
If the fault reappears and remains, then there wouldn't be an issue, an engineer would find it and make the repair.
28-03-2015 4:30 PM
28-03-2015 5:59 PM
28-03-2015 7:00 PM
28-03-2015 7:37 PM
If you use the red 2704n link in my sig, enter the password at the login screen, you'll see your stats. You could copy and paste them in a post.
29-03-2015 11:19 AM
29-03-2015 12:41 PM
29-03-2015 2:28 PM
29-03-2015 3:02 PM
Were you still experiencing the same issue you had in the first post of this thread?
29-03-2015 3:25 PM
The intermittent slow internet seems to have gone.
