New connection
- Re: New connection
New connection
22-09-2014 5:28 PM
Just did a speed test
http://www.speedtest.net/my-result/3779087690
To the same server with BT a couple of days back
http://www.speedtest.net/my-result/3775396027
Re: New connection
22-09-2014 8:38 PM
Re: New connection
22-09-2014 9:27 PM
If the switch of FTTC from BT to PlusNET causes a DLM reset (CRT can you advise please) then the line will run with an open profile for 48 hours (not the widely believed 10+ days) after which a profile will be established for the line. That profile will be passed on to PlusNET to establish the DATA speed for the line, which can be found here - https://portal.plus.net/my.html?action=data_transfer_speed
This speed should be the same as that reported above - 60Mbps. You might need to drop the PPP session on the router to get the full speed.
Re: New connection
23-09-2014 8:37 AM
Townman I've used that link and see the following:
Estimated line speed:
43Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-08-29 22:37:47
Current line speed:
78 Mb
The estimated speed is inline with the speedtest I'm getting, but surely it should be more if my current speed/sync speed is 78Mb!!!
Time to do something or just wait another 24-48 hours to see what happens?
My uptime is showing: 0 days, 15:32:47 which takes the time back to the exact time I first connected the router, so no dropouts.
Re: New connection
23-09-2014 8:45 AM
I also note that the BT speed test was taken at a quieter time than the ones you've done with Plusnet.
Re: New connection
23-09-2014 10:38 AM
http://www.speedtest.net/my-result/3769605154
http://www.speedtest.net/my-result/3769614730
http://www.speedtest.net/my-result/3776603998
And Plusnet done now at 10.33 on a Tuesday morning isn't what i'd expect to be peak time!
Down by around 20%
Re: New connection
23-09-2014 10:40 AM
If you run the BT Speed Test http://speedtest.btwholesale.com/ and click on Further Diagnostics, what's your IP Profile?
Re: New connection
23-09-2014 10:47 AM
IP Profile:
Download speedachieved during the test was - 42.51 Mbps
For your connection, the acceptable range of speedsis 32.53 Mbps-46.48 Mbps .
Additional Information:
IP Profile for your line is - 46.48 Mbps
Upload speed achieved during the test was - 10.27Mbps
Re: New connection
23-09-2014 10:53 AM
When your line is setup for the first time, it syncs at its fastest possible speed. But sometimes it will be unstable, so DLM will adjust it to provide stability.
Re: New connection
23-09-2014 11:00 AM
Re: New connection
23-09-2014 11:05 AM
Re: New connection
23-09-2014 11:17 AM
Re: New connection
23-09-2014 3:36 PM
Our tests have found a fault with your broadband service.
You've given us all the information we need about your problem, we'll raise this to our supplier for investigation.
