New connection only syncs at 286k
- New connection only syncs at 286k
14-12-2011 9:06 PM
Link Information
Uptime: 0 days, 0:20:43
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 3,940
Bandwidth (Up/Down) [kbps/kbps]: 440 / 286
Data Transferred (Sent/Received) [MB/MB]: 1.75 / 11.17
Output Power (Up/Down) [dBm]: 12.5 / 17.0
Line Attenuation (Up/Down) [dB]: 28.0 / 51.0
SN Margin (Up/Down) [dB]: 23.0 / 7.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 1,092
CRC Errors (Up/Down): 32 / 0
HEC Errors (Up/Down): 7 / 0
Re: New connection only syncs at 286k
14-12-2011 9:53 PM
The other thing.
Do you still have Sky TV and, if so, is the set top box plugged into the telephone system
14-12-2011 11:24 PM
15-12-2011 9:47 AM
15-12-2011 5:32 PM
15-12-2011 6:07 PM
I suggest you raise a speed fault via http://faults.plus.net
16-12-2011 9:32 AM
16-12-2011 9:52 AM
16-12-2011 1:29 PM
16-12-2011 3:00 PM
The connection is still dropping I'm afraid, which will be what's causing the slow speed. It won't go back to its former level until the fault is fixed and the line is stable. Thanks for raising the fault, we'll get you an update on the ticket as soon as we can.
16-12-2011 9:11 PM
19-12-2011 9:49 AM
