New Wireless Router/Modem - TRENDnet
- New Wireless Router/Modem - TRENDnet
19-04-2010 9:10 AM
Just purchased a TRENDnet wireless router and it will not connect to the internet. Have tried both 'auto' and 'manual' methods - no joy I'm afraid. Does anyone have any ideas?
Message 1 of 5
(1,080 Views)
4 REPLIES 4
Re: New Wireless Router/Modem - TRENDnet
19-04-2010 9:15 AM
does the router have a log with the error? someone will need that if they are to assist you.
Message 2 of 5
(566 Views)
19-04-2010 9:39 AM
which model router is it
Message 3 of 5
(566 Views)
19-04-2010 1:33 PM
Router is a TRENDnet Wireless G ADSL Modem Router - TEW435BRM. Another issue is the fact that it asks for a PIN number (which should be on the underneath of the modem; however, there isn't one). The pin should be either '4' or '8' digits in length.
Message 4 of 5
(566 Views)
19-04-2010 2:03 PM
Try contacting TrendNet for it, or Ask where you purchased the router, they should have some answers.
Also, Does it ask for the PIN in Windows or The router Managment page?
If in windows (Vista is the only one im aware of), On the Bottom Right or Left, Click "Use a Passphrase to connect" (or something like that, im not sure)
Regards
Aman
Regards
Aman
Message 5 of 5
(566 Views)
