New User, Bitterly Disappointed
- New User, Bitterly Disappointed
- « Previous
- 1
- 2
- Next »
Re: New User, Bitterly Disappointed
30-11-2009 7:48 AM
another PRO user with slows speeds ... 2 people does not make an epidemic and could be unrelated ... http://community.plus.net/forum/index.php/topic,81279.0.html
3Mb FTTC
3Mb FTTC
Message 16 of 22
(431 Views)
30-11-2009 8:06 AM
it could be the general very slow traffic last night, mine was down from 6000 to as low as 2000 for a long time last evening, most unusual for my line
Message 17 of 22
(431 Views)
01-12-2009 6:53 PM
@pugs
Any update on the queries in reply #10?
Forget which package you are on etc, you have a problem affecting your connection with the exchange we need to solve, this is not to do with PN's network.
Message 18 of 22
(431 Views)
03-12-2009 4:33 PM
Many thanks for all replies. TO answer the points raised in post 10 and to give more info:-
Not a gamer so I guess I can forget interleaving switch off
My PC is connected to a BT line box as shown.Plugged in is the microfilter (no means to identify) into which the printer/fax is connected. The router is a Thomson 565v7. Previously used a gas powered D-Link 604 when with ADSL24.
Update re speed. Download speed now seems to be stable at 2.9Mb. No longer an unhappy bunny!
Cheers
Cheers
Message 19 of 22
(431 Views)
03-12-2009 4:45 PM
Just jumping in here - but try double filtering the printer/fax
That is
BT socket
Filter 1 - router and filter 2 attached
Filter 2 - printer/fax attached
That is
BT socket
Message 20 of 22
(431 Views)
03-12-2009 5:05 PM
Double filtering reduced download speed to 2.36MBps. I thought ping was worse at89ms as its usually 36ms but testing with one fileter and no fax connected it was104ms. Maybe thats to do with the time of day?
Message 21 of 22
(431 Views)
03-12-2009 6:46 PM
Double filtering connected as Jim described will not affect broadband performance (filters do not filter the ADSL unless you connect to them incorrectly - the modem/router connection is directly to the line).
Unfortunately, the figures you quoted can vary at any time, but especially so at a busy time with some of the network problems lately - there's also been some maintenance work today which may have had some impact at certain times.
Message 22 of 22
(431 Views)
- « Previous
- 1
- 2
- Next »
