New Test Socket
valart
New Test Socket
The engineer as just left me and he fitted a test socket and tested my line and my speed is better but he said that I was some distant away from the exchange and is test machine showed 7.15 mb which is all I can get or lower,he was a really good guy he checked all my other boxes were good.I did have a little scare after he left because the line dropped a couple of times it seems to have settled down now maybe it was because my router was off for sometime I hope so.
Fixes: 35
Re: New Test Socket
Thanks for the update, it's beginning to sound like there was an issue with the estimate. Let me know if you need any further help from us.
 Adam Walker
Re: New Test Socket
How are your router stats now, compared to previously (http://community.plus.net/forum/index.php/topic,113542.msg976585.html#msg976585)?
valart
Re: New Test Socket
I have been on my laptop for the last 30 mins and I have had no line drops so far it might have settled down I will see how thing are I hope I have no more problems with these gremlins.
valart
Re: New Test Socket
Adam when you say there is a  estimate issue what does this mean.
Fixes: 21
Re: New Test Socket
This is getting confusing, that seems to be about 4 threads on this issue and wasn't easy to follow, but at least it seems to be fixed now. Posting your stats would enable us to see if you are now getting the best from your connection.
Re: New Test Socket
Based on valart's line attenuation figures previously - I would have expected a lot quicker than 7.15Mb
Fixes: 35
Re: New Test Socket
It could be that the original speed estimate given for your line wasn't right unfortunately.
Adam
 Adam Walker
Fixes: 4
Re: New Test Socket
Is his something daft like having an ADSL1 profile applied to an 21CN line ?
as a profile of 7.15Mbps is a bit suspiciously like ADSL1 running at full speed !
Fixes: 46
Re: New Test Socket
No he's on ADSL2+. Yet another thread started http://community.plus.net/forum/index.php/topic,113764.msg978291.html. His Plusnet profile should go up to 8.6Mbps (or perhaps higher). Hopefully the automated system will set that properly.
His speeds have doubled since his original enquiries, seems a fair result to me. Smiley
David
Re: New Test Socket
Looks like it's upped to 9891 now, hope it stays around there but things are definitely looking good.
