New Tecnicolor Router
stathe
Have a new router from Plusnet and my whole thing is very slow My profile being a fraction of what it was.How should I proceed
Results Image not loaded
1. Best Effort Test: -provides background information.
Download  Speed
0.49 Mbps
0 Mbps 0.5 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.49 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
Additional Information:
Your DSL Connection Rate :0.8 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.5 Mbps
Re: New Tecnicolor Router
Have you had connection problems recently?
Your speeds are slow because BT have set your IP Profile to 0.5Mb/s. Can you put your number in http://www.dslchecker.bt.com/ and see what it says about your estimated speeds?
Fixes: 62
If you post the full stats from your router - noise margin, speeds and attenuation we would have a better idea http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0 takes you to the right page
stathe
Link Information
Uptime: 0 days, 0:49:07
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 800
Data Transferred (Sent/Received) [MB/MB]: 2,90 / 14,58
Output Power (Up/Down) [dBm]: 11,9 / 14,4
Line Attenuation (Up/Down) [dB]: 31,5 / 63,5
SN Margin (Up/Down) [dB]: 12,0 / 12,1
Chipset Vendor ID (Local/Remote): BDCM / ALCB
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 67 / -
FEC Errors (Up/Down): 46 / 4.866
CRC Errors (Up/Down): 22 / 61
HEC Errors (Up/Down): -2 / 61 / 27
Are you connected to your master socket? Can you hear any noise like crackling or static on your phone line?
Your line is very noisy - actually off the scale. I don't think routers report anything above 63.5dB.
Fixes: 62
Judging by your attenuation and noise margin the speeds aren't too bad
However for some reason your default noise margin has increased to 12dB
Did you do a manual resync about 49 minutes ago or did the line just drop
stathe
We fixed up the new Router then and it has been all down hill it is in the main BT socket with a filter, phone OK I am on a long line but it has been acceptable until now
