New Tablet.
- Re: New Tablet.
New Tablet.
12-04-2013 1:14 PM
I am having trouble registering my new Tablet on Plusnet. just get message,"Authorisation problem". Can someone assist please.
Message 1 of 5
(812 Views)
4 REPLIES 4
Re: New Tablet.
12-04-2013 1:33 PM
which tablet
Message 2 of 5
(459 Views)
Re: New Tablet.
12-04-2013 2:05 PM
Sounds like you may not have the wireless password in correctly. It should be on a sticker on the base of the router (usually starting CP) - if you put that in does it make any difference?
Message 3 of 5
(459 Views)
Re: New Tablet.
12-04-2013 3:20 PM
Hmm, the router admin password will start with CP but the wireless key won't. The latter should be given under "Wireless Network" on the plastic card that came with the router (or on the underside of the router) and needs to be entered using capital letters. Note that 0 and 1 are digits and not letters.
David
Message 4 of 5
(459 Views)
Re: New Tablet.
12-04-2013 3:27 PM
Bah - always get those confused. Thanks spraxyt.
Message 5 of 5
(459 Views)
