New TP-Link modem router, very inconsistent ping when gaming.
- Re: Now TP-Link modem router, very inconsistent pi...
26-05-2017 1:45 PM - edited 26-05-2017 3:01 PM
I bought a new TP-Link Archer VR600, set it all up. General internet browsing/streaming is quick. But when I am gaming, the ping will go from 40 to 150, right up to 1200 then back down 40.
Does it on both Wifi connection and ethernet connection
I dont know if i have made a mistake with router set up
looking for help!
Re: Now TP-Link modem router, very inconsistent ping when gaming.
26-05-2017 2:59 PM - edited 26-05-2017 3:01 PM
Current Rate(kbps) | 1102 | 6510 |
Max Rate(kbps) | 1108 | 7224 |
SNR Margin(dB) | 6 | 6.7 |
Line Attenuation(dB) | 23.4 | 40 |
Errors(pkts) | 3616 | 48143 |
26-05-2017 4:05 PM
Have you double checked that nothing is using the upload whilst you're gaming? If anything saturates the upstream you may see ping spikes or similar.
26-05-2017 10:22 PM
99% no other devices are uploading. i have changed all adsl filters etc to no avail. . .
currently sitting at a consistent 200 ping which for fps games online is NOT good.
27-05-2017 5:40 PM
nothing to add? anyone? modem router settings which i can cross reference to make sure everything is correct? its highly unusual that even with ethernet there are lag spikes.
29-05-2017 9:17 AM
