New TG582n FTTC firmware - 10.2.5.2 - For testing
- New TG582n FTTC firmware - 10.2.5.2 - For testing
Re: New TG582n FTTC firmware - 10.2.5.2 - For testing
02-07-2013 1:11 PM
02-07-2013 5:50 PM
02-07-2013 6:59 PM
02-07-2013 7:13 PM
02-07-2013 7:19 PM
Damian78, it took me about 20 mins from start to finish, to update, i followed anotherone's instructions, with no issues at all.
02-07-2013 7:23 PM
May try at weekend then.
02-07-2013 8:21 PM
03-07-2013 5:12 PM
03-07-2013 6:32 PM
22-07-2013 6:04 AM
After updating to '10.2.5.2.EO', I found an issue to report.
Attempting to access the 'Remote Assistance' (under 'Toolbox') will result in a '500 - Internal Server Error'.
Regards,
Jerotire
22-07-2013 4:20 PM
The login is somewhat annoying because it doesn't remember the username and won't let the browser (Firefox) remember the password either ???. Am I missing something, is there a way to get the landing page to remember the username like it used to with version 8.C.M.0?
BTW I have only one username set up and naturally it's the default.
03-08-2013 11:50 AM
When I have my WLAN Security setting "Allow New Devices" set to "New stations are allowed (via registration)", when I remove a device from the Devices list, they are able to reconnect a few seconds later without me needing re-activate "Search for wireless devices" (registration mode).
Quote from: silloyd The login is somewhat annoying because it doesn't remember the username and won't let the browser (Firefox) remember the password either ???. Am I missing something, is there a way to get the landing page to remember the username like it used to with version 8.C.M.0?
Maybe this can help, someone mentioned something similar to this earlier in this thread:
Quote from: npr Got fed up with the login screen defaulting to "admin".
So I've hunted out the command to make it default to my own pre-configured username: npr
cli command:
env set var=DefUser value=npr
You'll need to telnet into the router to execute the command. The username and password are the same as you currently use to enter the web administration panel.
Linux should be easy, however if you're on windows and don't have telnet, you can install via "Turn Windows features on or off" or use PuTTY:
http://www.chiark.greenend.org.uk/~sgtatham/putty/
03-08-2013 12:22 PM
It wasn't until I'd moved back that I realised how painfully slow the interface was with the new firmware.
03-08-2013 4:10 PM
Quote from: Jerotire Attempting to access the 'Remote Assistance' (under 'Toolbox') will result in a '500 - Internal Server Error'.
Isn't error 500 a permission issue?
09-10-2013 6:30 PM
