New TG582n FTTC firmware - 10.2.5.2 - For testing
- Re: New TG582n FTTC firmware - 10.2.5.2 - For test...
10-05-2013 5:01 PM
I know there's been some demand for this as an ADSL version of this firmware track has been available for some time, but not an FTTC verson.
The firmware is available here: http://products.plus-payh.co.uk/firmware/
It is for DEMO ONLY! You may need to flash back to the 8.C.M.0 version if something isn't working (however we've tested it and found no functional problems).
Features include:
Ability to switch to ADSL mode
A new dashboard at 192.168.1.254 viewable without logging in
IPv6 support (my IPv6 In IPv4 tunnel tutorial is here. http://community.plus.net/forum/index.php/topic,106578.0.html)
Wifi auto channel selection - based on actual utilisation of each channel
Improved manual setup wizard
Wifi on/off scheduling
Pressing the enter key on the login page now logs you on
Better intercept pages if the WAN is down
Try it out and let me know what you think.
Thanks,
Matt
Re: New TG582n FTTC firmware - 10.2.5.2 - For testing
10-05-2013 6:49 PM
10-05-2013 7:01 PM
Will it still allow the usb media port to used and if so is it still held back on FAT32 or has that feature been upgraded to NTFS?
podman
10-05-2013 7:30 PM
Edit: having just read a few posts which previously stated that NTFS may have too much overhead then what about using ExFat as an alternative. At least this would break the 4 Gig barrier.
10-05-2013 8:25 PM
It's been said previously that they weren't going to do a mass upgrade, it can be done remotely on request, or eventually shipped in the routers.
@booji
ExFat is even less well supported on the router (Linux) than NTFS. NTFS probably isn't supported because it costs extra. There's no sign of the Paragon NTFS software in Plusnet's 10.2.5.2.
10-05-2013 8:30 PM
I did read that I should be able to attach drives via a USB hub which does appear to be the case but only one can be managed at a time with the user having to log in and swap between either in the router settings. Not really practical.
10-05-2013 8:33 PM
Quote from: ejs NTFS probably isn't supported because it costs extra.
I don't buy into the extra cost excuse.
If there's a fee for supporting NTFS, why is it supported by Linux?
10-05-2013 8:37 PM
10-05-2013 8:41 PM
Anyway, Matt, when switching from FTTC mode to ADSL will all four LAN ports be available?
10-05-2013 9:13 PM
10-05-2013 9:22 PM
Quote from: Anotherone Anyway, Matt, when switching from FTTC mode to ADSL will all four LAN ports be available?
Yes, a message on screen tells you that you can now use Port 4 for the LAN.
10-05-2013 9:50 PM
10-05-2013 10:25 PM
10-05-2013 10:48 PM
Tried two telnet methods, both failed.
10-05-2013 11:16 PM
Everything else has been fine so far this evening, not bad!
The NTP lookup failed initially but is working ok now.
I'll keep trying to break it
