New Static IP - Points to someone else's account!
- New Static IP - Points to someone else's account!
26-06-2014 6:35 PM
I have just come back to PlusNet (I was here in the dialup days) with FTTC, and activated Static IP address. The thing is though, it is pointing to someone else's account! <removed>
I have added an "A" record to the DNS settings of the domain I host with you, which will hopefully override the user name, but I'd be obliged if someone could just check things are ok?
Cheers!
Mike
jim:green I have removed the personal data but copied it to the hidden forums for staff mod:end
Re: New Static IP - Points to someone else's account!
26-06-2014 6:41 PM
Welcome to the forums and to PlusNet. Have you checked your IP here - https://portal.plus.net/my.html?DDrh49Aa3SeIYl4N3BTJlhGvNgoXUgKqC3f0fFmIgOsmrrsujjYNOs1jIhDFyttD - if that link does not go to the right place, you need to log into to the portal and look at the static IP page under connections.
There was a report recently of someone who asked for a static IP, however the address reported on the payments page was not the one actually allocated to him. There was a two address difference. It has been suggested that there might be an issue with address selection and address allocation process.
This might though be a red herring!
Kevin
26-06-2014 6:51 PM
If the static IP is newly allocated changing it's DNS settings could be in progress.
26-06-2014 6:55 PM
26-06-2014 7:15 PM
Mike
26-06-2014 7:59 PM
27-06-2014 1:51 PM
28-06-2014 1:05 AM
Cheers!
28-06-2014 10:41 AM
