New RouterI wa
valart
New RouterI wa
I was in PC World this morning and I noticed a TP Link wireless router selling for £20 can you advise me if this router is alright for the price and is it easy to set up because I am not to good with all this tech,when I set up the PN router all those years ago the password was the on a sticker under the roluter.
Re: New RouterI wa
Is this for fibre/ADSL? Do you know the model number? Any reason you want to replace your existing router?
valart
Re: New RouterI wa
The model number isTL WR841N 300mps it is not fibre the reason for change is that on average my router disconects on average about a couple of times in a month although it reconects very quickly.I might be over cautious but I like to have another router if this one is on it's way out.
Re: New RouterI wa
This is a fibre router - it will not work with ADSL.
I think the thing to do is figure out why you are getting disconnections as it is unlikely changing a router will help.
valart
Re: New RouterI wa
Somebody in the forum suggested it could be a faulty router it was not my idea.
Re: New RouterI wa
It would be unlikely (also given you have had problems with your line before). Routers either tend to work or not work and it's pretty rare to have a faulty one.
