New RouterI wa
- Re: New RouterI wa
New RouterI wa
19-10-2013 3:20 PM
I was in PC World this morning and I noticed a TP Link wireless router selling for £20 can you advise me if this router is alright for the price and is it easy to set up because I am not to good with all this tech,when I set up the PN router all those years ago the password was the on a sticker under the roluter.
Message 1 of 6
(759 Views)
5 REPLIES 5
Re: New RouterI wa
19-10-2013 3:28 PM
Is this for fibre/ADSL? Do you know the model number? Any reason you want to replace your existing router?
Message 2 of 6
(450 Views)
Re: New RouterI wa
19-10-2013 3:53 PM
The model number isTL WR841N 300mps it is not fibre the reason for change is that on average my router disconects on average about a couple of times in a month although it reconects very quickly.I might be over cautious but I like to have another router if this one is on it's way out.
Message 3 of 6
(450 Views)
Re: New RouterI wa
19-10-2013 3:55 PM
This is a fibre router - it will not work with ADSL.
I think the thing to do is figure out why you are getting disconnections as it is unlikely changing a router will help.
Message 4 of 6
(450 Views)
Re: New RouterI wa
19-10-2013 6:32 PM
Somebody in the forum suggested it could be a faulty router it was not my idea.
Message 5 of 6
(450 Views)
Re: New RouterI wa
19-10-2013 6:47 PM
It would be unlikely (also given you have had problems with your line before). Routers either tend to work or not work and it's pretty rare to have a faulty one.
Message 6 of 6
(450 Views)
