New Router
- Re: New Router
New Router
24-02-2014 5:32 PM
I am thinking of getting a new router the one that I have got is about seven years old from when I joined PN and is working fine at the moment but I thought I liked be prepaired and have one on stand by just in case.I noticed that Amazon have a TP Link TLWR841 wireless router priced at £15.99 any advise would be welcome and is it easy for a pensioner like me to set it up.
Message 1 of 7
(1,057 Views)
6 REPLIES 6
Re: New Router
24-02-2014 5:43 PM
Plusnet will provide a a free tg582n if you don't mind a new contact?
Maybe a home hub 4 or 5 ?
Easy to use all in one {Think of that, well know auction site, for best prices}
Message 2 of 7
(576 Views)
Re: New Router
24-02-2014 6:25 PM
The TLWR841 is a cable router not an ADSL router - if you are still on ADSL and not FTTC it won't be much good for what you're after.
If you are on FTTC though, these are pretty good - I use a couple myself but have reflashed them with DD-WRT as the stock firmware became a little unstable during large LAN to Wireless file transfers.
Message 3 of 7
(576 Views)
Re: New Router
24-02-2014 7:48 PM
I did mention that I was a pensioner and may sound silly to most but I don't know if I am ADSL or FTTC
Message 4 of 7
(576 Views)
Re: New Router
24-02-2014 7:57 PM
If you've not upgraded your modem/router for the last 5+ years you'll probably be on ADSL so you'll need a "modem router" rather than a "cable router"
If your current router plugs into a separate BT modem which then plugs into your phone line then you are on FTTC. If your current router plugs straight into your phone socket via a microfilter then you'll be on ADSL.
Message 5 of 7
(576 Views)
Re: New Router
24-02-2014 8:18 PM
Handy Guide to FTTC ( fast fibre broadband) Have the tea & biscuits at the ready
https://www.plus.net/home-broadband/package-guides/fibre-optic-broadband
Message 6 of 7
(576 Views)
Re: New Router
24-02-2014 8:48 PM
Thanks for your reply the router goes straight into the phone socket so it is ADSL
Message 7 of 7
(576 Views)
