New Router Won't hold the line
- New Router Won't hold the line
- « Previous
- 1
- 2
- Next »
Re: New Router Won't hold the line
30-07-2012 11:37 AM
Hi Matt,
As it turns out, Draytek supplied me with a patch which means that it has been in play since late Thurs. I caused the drop on Sunday - no idea what Friday's was. This morning seems to be the router re-syncing at a higher sync as the current stats are:
So, it seems that the line has synched back to a good level .
Having said that, could you switch my line back to fastpath with uncapped upload speed?
Cheers,
Allwork
Quote from: Matt Hi there,
Looks like there were one or two drops:
Not sure if they were reboots by yourself though, but it does look like interleaving was applied to the line automatically on Sunday - profile hasn't dropped too much as a result though and is currently set to 5865 on BTs side and matched at 5800 on our side.
> adsl status
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : ADSL2+(G.992.5) State : SHOWTIME
DS Actual Rate : 6648000 bps US Actual Rate : 888888 bps
DS Attainable Rate : 7852000 bps US Attainable Rate : 888000 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 511 US Interleave Depth : 8
NE Current Attenuation : 42 dB Cur SNR Margin : 7 dB
DS actual PSD : 18. 8 dB US actual PSD : 12. 3 dB
ADSL Firmware Version : 232201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 18 dB Far SNR Margin : 13 dB
CO ITU Version[0] : 00004946 CO ITU Version[1] : 0000544e
DSLAM CHIPSET VENDOR : < IFTN >
Cheers,
Allwork
Message 16 of 17
(204 Views)
31-07-2012 12:12 PM
You connection has now become stable, I have placed the order for fastpath and set your upload to uncapped. This will take one working day to complete.
Hope this helps.
Hope this helps.
Message 17 of 17
(204 Views)
- « Previous
- 1
- 2
- Next »
