New Pro User - Be gentle
- New Pro User - Be gentle
04-03-2011 9:34 PM
Im Currently on the Pro Package (I went for the no contract option as I wanted to try before I commit)
Im now 5 days into the 'test' period and at this point in time I admit not overly impressed. but am still open minded
I do have a few questions.
Ip profile 1500k, ( Currently synching at 2400 ) will this change Or do I have to ask?
Why the poor upload sub 600 again do I have to ask for this also to be upped?
Why do speed / ping testers tell me Im in london both on static and dynamic?
Latency - 34 - 35ms to bbc.co.uk the best I have managed so far .
Packet loss stats Higher than anticipated with traceroutes showing 10 hops to the same.
Pinging www.bbc.net.uk [212.58.246.91] with 32 bytes of data:
Request timed out.
Request timed out.
Reply from 212.58.246.91: bytes=32 time=49ms TTL=55
Reply from 212.58.246.91: bytes=32 time=34ms TTL=55
Ping statistics for 212.58.246.91:
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Approximate round trip times in milli-seconds:
Minimum = 34ms, Maximum = 49ms, Average = 41ms
Pinging www.bbc.net.uk [212.58.246.95] with 32 bytes of data:
Reply from 212.58.246.95: bytes=32 time=55ms TTL=55
Reply from 212.58.246.95: bytes=32 time=48ms TTL=55
Reply from 212.58.246.95: bytes=32 time=43ms TTL=55
Reply from 212.58.246.95: bytes=32 time=50ms TTL=55
Ping statistics for 212.58.246.95:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 43ms, Maximum = 55ms, Average = 49ms
Pinging www.bbc.net.uk [212.58.246.93] with 32 bytes of data:
Request timed out.
Reply from 212.58.246.93: bytes=32 time=900ms TTL=55
Reply from 212.58.246.93: bytes=32 time=892ms TTL=55
Reply from 212.58.246.93: bytes=32 time=856ms TTL=55
Ping statistics for 212.58.246.93:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 856ms, Maximum = 900ms, Average = 882ms
And finally will this level of performance be the norm for the package Or should it improve.
Regards
Oxymoron
Re: New Pro User - Be gentle
04-03-2011 9:47 PM
With a sync of 2400kbps the IP profile will rise to 2000kbps
Upload is normally only 448kbps until it is uncapped
The speed/ping testers think you are where the Plusnet edge routers are
Latency - you are almost certainly interleaved - this can be taken off by request but it is better to wait until after the training period
We now need some information from you so that we can see if you have a problem or you are just a long way from the exchange.
Can you log in to the router and copy the stats (noise margin, attenuation and speeds both up and down)
If you don't know how to get them this will explain http://www.kitz.co.uk/adsl/frogstats.php
04-03-2011 10:04 PM
Status: Showtime
Retrain Reason: 8000
Max: Upstream rate = 868 Kbps, Downstream rate = 2688 Kbps
Channel: INTR, Upstream rate = 672 Kbps, Downstream rate = 2400 Kbps
Link Power State: L0
Mode: G.DMT
TPS-TC: ATM Mode
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 2.1 11.0
Attn(dB): 50.0 31.5
Pwr(dBm): 17.9 12.6
G.dmt framing
K: 76(0) 22
R: 14 16
S: 2 8
😧 16 4
Counters
SF: 1658371 1658331
SFErr: 5795 4
RS: 56384626 14095813
RSCorr: 4749978 78
RSUnCorr: 23097 0
HEC: 4826 3
OCD: 11 0
LCD: 0 0
Total Cells: 159543522 0
Data Cells: 4928955 0
Drop Cells: 0
Bit Errors: 0 0
ES: 2365 0
SES: 9 0
UAS: 22 22
AS: 28193
INP: 1.34 1.33
PER: 1.75 1.75
delay: 8.00 8.00
OR: 32.00 32.00
Bitswap: 1644 34
Thanks for the reply.
I understand about the speed restriction of my line and that package cannot improve what isnt there
I dont do a lot of downloading However It would be nice to have the throughput at least close to the synch.
And as I was asking a bank of questions thought I would throw that in as well/
I chose Pro primarily for the low latency.
When I get back from work I do like to pew pew to unwind.
From the test socket - no extensions - router - Billion 7800 ( broadcom chipset) - connection method wired only. no noise via QLT.
Regards
Oxymoron
04-03-2011 10:31 PM
These are from my connection and it isn't a very clean line
Downstream
Noise Margin: 3.4 dB
Connection Rate: 4960 Kbps
Line Attenuation: 50.0 dB
By comparison your speed is very low indeed.
Do you have another filter/cable/router you can try.
Don't try it until tomorrow as reconnecting now will just drop your speeds even more
The fact that the upstream rate isn't higher would indicate some electrical noise on the line
This is from my connection (I am not on ADSL2+)
Upstream
Noise Margin: 24.0 dB
Connection Rate: 448 Kbps
Line Attenuation: 24.5 dB
Power: 12.5 dBm
Max Rate: 1180 Kbps
05-03-2011 12:54 PM
And a Draytek 2800.
No radical improvement . Which tbh I wasnt expecting so back to the Billion.
Unfortunately all the testing I did has only moved my profile further down to 1250k , &512 down and up respectively.
> adsl info --show
adsl: ADSL driver and PHY status
Status: Showtime
Max: Upstream rate = 732 Kbps, Downstream rate = 2528 Kbps
Channel: INTR, Upstream rate = 544 Kbps, Downstream rate = 2208 Kbps
Mode: G.DMT
TPS-TC: ATM Mode
Trellis: ON
Down Up
SNR (dB): 3.4 11.0
Attn(dB): 51.0 31.5
Pwr(dBm): 17.9 12.6
G.dmt framing
K: 70(0) 18
R: 14 16
S: 2 8
😧 16 4
Counters
SF: 43305 43245
SFErr: 3 60
RS: 1472382 367582
RSCorr: 39015 1622
RSUnCorr: 6 0
HEC: 2 41
OCD: 0 33
LCD: 0 6
Total Cells: 3833633 0
Data Cells: 127321 0
Drop Cells: 0
Bit Errors: 0 0
ES: 3 0
SES: 0 0
UAS: 47 47
AS: 736
INP: 1.45 1.60
PER: 1.75 1.75
delay: 8.00 8.00
OR: 32.00 32.00
Bitswap: 156 2
Latency still poor at 34ms to bbc.net .
Im beginning to edge towards the opinion, that its very lucky I didnt sign up for a 12 month stint. As I appear to be on a very fast downward spiral to a very very slow & laggy end.
Regards
Oxy
05-03-2011 12:57 PM
34ms is about right for an interleaved line
05-03-2011 1:13 PM
I do beg to differ on the latency induced by the interleave being the root cause of the lag.
previous Isp with a 32 bit interleave pings to bbc.net consistantly 24-27ms 19ms on a good day.
That was with a much higher INP value with its resulting latency footprint.
Could it be that my signal appearing to have to travel 200 miles to london to get on the backhaul servers be more to blame.
What would be the bast way to get my profile closer to my synchspeed,
Regards
Oxy
05-03-2011 1:32 PM
05-03-2011 5:39 PM
This does lead to the smell of back door traffic / capacity management . which on a perceived premium product, for me is unacceptable.
Roll on Monday .
Oxy
07-03-2011 12:04 PM
Are you using extension sockets/cables to plug your filter into? If so can you try the test socket?
Jojo
07-03-2011 12:33 PM
Just ran a line test and it looks like the reason you were getting lower speeds that you IP profile was due to inconsistent speeds on the bRAS and MSAN. I've now rectified that so you should see the difference shortly. As for the overall speed that's a different matter, just need to know firstly about the test socket.
Jojo
07-03-2011 7:59 PM
As stated in my first post all data from the test socket - no extensions , 1m rj11.
Cannot confirm any throughput increase as I work away from home 5 days a week.
However as the throughput is effectively traffic managed via these "profiles" . and should my line drop the profile drops never to return upward unless via intervention. It does seem a pointless exercise to continue using yourselves.
Oxy
07-03-2011 10:21 PM
As your line is in the 10 day training period there's nothing we can do at the moment. We can't raise any faults against the line and there can be fluctuations before it settles down.
Jojo
08-03-2011 8:08 AM
Quote from: Oxymoron However as the throughput is effectively traffic managed via these "profiles" . and should my line drop the profile drops never to return upward unless via intervention. It does seem a pointless exercise to continue using yourselves.
For a 50dB attenuation, the speeds you are getting are approximately in the right range.
Also, these 'profiles' are actually imposed by BT, this is a part of how BT make ADSL work in the UK, many of us do not like it and it is extremely hard for BT to justify it working this way. But they do. What this means for you, is that these 'profiles' will be a problem for *you* for any ISP that you choose, it is not PN being the cause of this problem on this occasion.
Yes, it can take 3 or 4 days for the changes to the BT 'profiles' to take affect.
3Mb FTTC
08-03-2011 4:56 PM
Quote from: Oxymoron Hi thanks for your replies.
Oxy
If you want to get away from BT's draconian DLM system then have a look to see if there are any LLU providers in your exchange.
